[SOLVED] How to import planned Workouts from Today's Plan?
Hi there,
similar questions have been asked for Garmin and other platforms already, but I did not find anything for Today’s Plan.
I receive my planned workouts through Today’s Plan.
I already connected Garmin and Garmin is receiving the structured workouts. So I am able to use my Watch to follow the instructions. But it seems that Garmin is not giving these structured workouts (pre activity) to intervals.icu
Is it possible to send the Today’s Plan workouts to intervals.icu directly?
If I extract them manually via FIT-File from Today’s Plan and upload them manually into intervals.icu there is another burden: Today’s Plan is adding a recovery step (ended by “LAP-Button”) automatically after each planned recovery step. Intervals.icu is then reflecting 10min more to the plan beased on this step.
Sorry if I am not clear and understandable due to my bad English. I will be happy to answer questions if needed to clarify my problem here.
Thanks again,
Andreas
I think probably fit file import is your best bet. I had a quick look at Todays Plan’s integrations and didn’t see any way to get workouts directly to Intervals.icu. If they supported DropBox then something could be done.
Andreas,
not sure if this is of any help but you can sync your Today’s Plan calendar with your Intervals.icu calendar.
By doing that you will at least have your planned workouts in Intervals.icu as calendar entries. Planned load is calculated, planned and completed workouts will be matched and the entry in Intervals.icu will include a direct link to the workout in Today’s Plan. I find this integration quite neat.
Thanks for the tip! It solves the issue easily.
I love that folks are working so hard to get data in Intervals from the “leaders”.
After March 12, 2024 this will be irrelevant because Today’s Plan is closing their doors on that date. Wonder where everyone will migrate?
Hello, thanks for the tips. On my side the calendar sync is ok , but ii shows only the next event of the current month (or the next 30 days, i will see this tomorrow). It is normal ?
Ok the problem is a the source: in the ics generated by what today plan… it does not contains all scheduled training (it is limited to today to Day+30)… ok i need to find another way to import my full plan :slight_smile:
