[SOLVED] How to import planned training from Garmin connect (not doable)
Hi, I am Michael and completely new to intervals.icu. I tried to import my planned trainings in intervals but didn’t succeed. The synch features of Garmin are all activated, I also tried to disable and activate again. I would expect that at least the next week of training plans would be visible to derive the impact of the planned training to fatigue, fitness and from. Is this achievable. How do you do this?
Michael
I’m fairly sure you can’t import their (Garmin) calendar here.
Garmin doesn´t allow that. You can only send planned training.
Thanks for the clarification. Can you tell how that would work „To send training “?
It´s the other direction. Plan in Intervals and send it to Garmin.
It is possible - but not very straightforward. You could connect your watch to your computer and use the fit-files in “WORKOUTS” → “PLANNED” (something like that. Can’t look it up right now). These files can be imported into intervals.icu als planned (and structured) workouts.
Hi, many thanks. That worked at first glance. Easy to access the fit files under „workouts“. I imported one in the caledandar. It synchronized with garin connect and my Fenix 6. however, starting the training on the watch it didn’t work as expected. It seems during the copy/import process the fine structure was damaged as the training starts with a long list of 1 minute exercises. I assume those a the short breaks I had defined Ami g repetitions of my strength training within a set. Any idea how to avoid that?
Here the full text which had been imported…
——- schnipp ———-
  • Aufwärmen 5m Z1 HR (106-133bpm)
  • 1m Z1 HR (106-133bpm)
  • Cooldown 5m Z1 HR (106-133bpm)
step [1]: Unhandled duration_type: REPS message_index=1 intensity=0 target_type=2 target_value=0 secondary_target_value=0 duration_type=29 duration_value=12 exercise_category=28 exercise_name=0 exercise_weight=95.0 weight_display_unit=1 step [3]: No step found for duration_value 1 duration_type=6 target_value=3 message_index=3 duration_value=1 unknown=0 step [4]: Unhandled duration_type: REPS message_index=4 intensity=0 target_type=2 target_value=0 secondary_target_value=0 duration_type=29 duration_value=12 exercise_category=21 exercise_name=13 exercise_weight=55.0 weight_display_unit=1 step [6]: No step found for duration_value 4 duration_type=6 target_value=3 message_index=6 duration_value=4 unknown=0 step [7]: Unhandled duration_type: REPS message_index=7 intensity=0 target_type=2 target_value=0 secondary_target_value=0 duration_type=29 duration_value=12 notes=Trizepepsdrücken an der Kordel exercise_category=30 exercise_name=42 exercise_weight=15.0 weight_display_unit=1 step [9]: No step found for duration_value 7 duration_type=6 target_value=3 message_index=9 duration_value=7 unknown=0 step [10]: Unhandled duration_type: REPS message_index=10 intensity=0 target_type=2 target_value=0 secondary_target_value=0 duration_type=29 duration_value=12 exercise_category=14 exercise_name=6 exercise_weight=55.0 weight_display_unit=1 step [12]: No step found for duration_value 10 duration_type=6 target_value=3 message_index=12 duration_value=10 unknown=0 step [13]: Unhandled duration_type: REPS message_index=13 intensity=0 target_type=2 target_value=0 secondary_target_value=0 duration_type=29 duration_value=12 notes=Beinbeuger exercise_category=15 exercise_name=1 exercise_weight=50.0 weight_display_unit=1 step [15]: No step found for duration_value 13 duration_type=6 target_value=3 message_index=15 duration_value=13 unknown=0 step [16]: Unhandled duration_type: REPS message_index=16 intensity=0 target_type=2 target_value=0 secondary_target_value=0 duration_type=29 duration_value=12 notes=Legextension exercise_category=6 exercise_name=34 exercise_weight=50.0 weight_display_unit=1 step [18]: No step found for duration_value 16 duration_type=6 target_value=3 message_index=18 duration_value=16 unknown=0 step [19]: Unhandled duration_type: REPS message_index=19 intensity=0 target_type=2 target_value=0 secondary_target_value=0 duration_type=29 duration_value=12 exercise_category=24 exercise_weight=23.0 weight_display_unit=1 step [21]: No step found for duration_value 19 duration_type=6 target_value=3 message_index=21 duration_value=19 unknown=0 step [22]: Unhandled duration_type: REPS message_index=22 intensity=0 target_type=2 target_value=0 secondary_target_value=0 duration_type=29 duration_value=12 notes=Brustpresse exercise_category=0 exercise_name=12 exercise_weight=35.0 weight_display_unit=1 step [24]: No step found for duration_value 22 duration_type=6 target_value=3 message_index=24 duration_value=22 unknown=0 step [25]: Unhandled duration_type: REPS message_index=25 intensity=0 target_type=2 target_value=0 secondary_target_value=0 duration_type=29 duration_value=12 notes=Butterfly Positiv exercise_category=9 exercise_weight=35.0 weight_display_unit=1 step [27]: No step found for duration_value 25 duration_type=6 target_value=3 message_index=27 duration_value=25 unknown=0 step [28]: Unhandled duration_type: REPS message_index=28 intensity=0 target_type=2 target_value=0 secondary_target_value=0 duration_type=29 duration_value=12 notes=Butterfly negativ exercise_category=9 exercise_weight=35.0 weight_display_unit=1 step [30]: No step found for duration_value 28 duration_type=6 target_value=3 message_index=30 duration_value=28 unknown=0 step [31]: Unhandled duration_type: REPS message_index=31 intensity=0 target_type=2 target_value=0 secondary_target_value=0 duration_type=29 duration_value=12 exercise_category=6 exercise_name=79 exercise_weight=35.0 weight_display_unit=1 step [33]: No step found for duration_value 31 duration_type=6 target_value=3 message_index=33 duration_value=31 unknown=0 step [34]: Unhandled duration_type: REPS message_index=34 intensity=0 target_type=2 target_value=0 secondary_target_value=0 duration_type=29 duration_value=12 exercise_category=13 exercise_weight=75.0 weight_display_unit=1 step [36]: No step found for duration_value 34 duration_type=6 target_value=3 message_index=36 duration_value=34 unknown=0
—- schnapp——
and if you remove the sync of plans to Connect? It should use then the training which is anyway already there…
So you load up the workout to ICU but don’t sync it back
Yes that’s clear, but I would like to use the cycling and swimming options from intervals. And: I would like to see a preview of the planned TSS in the next two weeks to estimate whether it’s the right load to not raise fatigue too much.
read my message again… if you import your workout from connect, you have all of that but execute the workout as planned from connect…
So you can see all that data in ICU
