[SOLVED] Create Workout manually
I wanted to share my Polar calendar with intervals.icu. It worked but somehow de calendar stops sharing after some period of time (it provides workouts till some date and after that date it shows no workouts entirely). On top of that, the information shared by Polar only contains text. So no visuals of the power zones (which I want to be in there because when I finish a workout Intervals.icu always tells me how I performed).
To solve this I decided to put in the data (time in powerzones, cadance etc.) myself. However, when I program a workout myself the visuals also aren’t displayed. Only text appears. So everything (in planning running workout though) fails till now… I don’t know if that matters because maybe intervals.icu compares my finished workout by the text i’ve put in?
Hope to get some insight from you all. thanks
Figured it out myself, i’ve found out that I should put an “m” for minutes and not a “:” between minutes and seconds… now the zones are displayed
Life is good now
