Small UI bug (but annoying) on the fitness site
hi,
If you have more charts and they don.t fit the screen, they scroll like a website (thats good), but the bottom info box (with activity name and basic info) stays on bottom of the website so is not visible until you scroll all way down (thats bad). At the same time the top menu works great and when you scroll down it stays on top of the screen instead the top of the website being visible all the time. Is it possible to make the bottom box work like the top so it is glued to the bottom of the screen when you scroll up? It would make the fitness chart much more user friendly, so when you look at the charts you see basic activity info all the time on the bottom (especialy the name of the activity)
cheerz
I tried to make that work without much luck. There can be several activities on a given day which makes it tricky.
Would be possible to toggle whether the activity summaries are visible?
Good idea, what about a fixed box that you can scroll to the sides in case there are too many activities?
