Where do I uncheck for past activities “show on fitness line”. Recently the white dots started showing up on the fitness line.
Look for the notes on your calendar, then uncheck “show on fitness…”
Yes I saw that in another thread and in my calendar I don’t see that option. I do see that option for each planned activity, which i’ve ensured is unchecked. Do you mind showing me visually where you see the “show on fitness”?
I’ve created white dots for the next few days.
On the calendar, there is a note called “test”, also showing in white.
If I click on the note, it shows the following, which the “show on fitness line” at the bottom.
Once unticked, the note will still show on the calendar, but it’s not on the fitness line.
Thank you !
