Under Settings I have manually entered my FTP but this has been applied to every historic workout, can FTP be set to apply from a certain date ? The same question for manually entered W’
Go to Activity List View (not calendar view) and select the workouts for the date range that you want to modify manually or by one of the available filter options… Then click on edit at the top and choose Edit.
You can change FTP, Weight and/or W’.
Thank you MedTechCD
Is there a way to reset my zone/power settings of a certain sport?
For some reason I’ve set FTP for running on 200 but I can’t get it undone.
Because of this settings the site gives me an extra tab for running in for example the power curve page.
Go to Settings on left side menu. Then under your personal info (e.g, sex, DOB, etc…) you’ll see sports (e.g., ride, run, swim, whatever you may have added). Select run and set your run specific settings including FTP there.
I’ve already found that page but I can only set a different FTP, I can’t reset it to nothing or ‘?’ like it is with people I follow. I have no idea what my running FTP is as I never run
Unfortunately you can’t unset that at the moment.
This gone done:
A related question
I have uploaded files from prior to Nov '20 when I first used a PM
For all these old files I’ve set the FTP to 999. Is there a way to leave FTP blank for these activities?
Not currently. You best bet is to go with something “reasonable” so charts going back that far don’t suddenly jump up.
