Solved.
Sorry, small mistake.
Script is working now.
Solved.
Hi David,
the alphaHRV app now provides an additional field called āreadiness alphahrvā, which apparently tries to quantify how ready you are based on the alpha1 during warm-up as compared to your previous few warm-ups. Iāve confirmed the field is present in the fit file using fitfileviewer. Could you add this to the data model so we can access it through intervals.icu? Iād be interested in tracking it over time.
Thanks, that works! I had actually searched for a field called āReadinessā, but only looked in the āFieldsā tab rather than āCustomā (step 1).
Hello, is there any stream available to access for a cadence curve?
Not at the moment. You would need to compute that from the cadence stream (and time if you want to be very accurate).
@david , how do you specify a request to return your all time personal best Power or HR? The only script I can find requires a retro number of days to specified. e.g., 42 days
You can use āallā:
let pc = icu.bestPower['all']
let best5mWatts = pc.getWatts(5 * 60)
console.log("best5mWatts", best5mWatts)
@david hoping you can help. Iām assuming this topic covers the custom activity scripts?
if this (below) is the script for best power (for 5m), what is the script to get it in the W/Kg equivalent, based on the riderās weight on the day of the activity?
icu.powerCurve.getWatts(5 * 60)
Then as an alternative script, how would the same two scripts show the same best power after a certain work value, eg. 1500kJ?
You can just do:
icu.powerCurve.getWattsPerKg(5 * 60)
For fatigued curves use icu.powerCurveFatigued0
and icu.powerCurveFatigued1
. The number of kJ of work before each depends on what has been configured for the athlete. It is available as icu.powerCurveFatigued0.after_kj
etcā¦
Would it be possible to get submax efforts too?
I have added up to 5 submax curves. Will deploy Monday AM. You will be able to do:
let pc = icu.bestPower['42d']
for (let i = 0; i < pc.submax_watts?.length; i++) {
console.log("submax_watts[" + i + "] = " + pc.submax_watts[I])
console.log("submax_watts_per_kg[" + i + "] = " + pc.submax_watts_per_kg[i])
submax_watts[0] = 757,748,735,720,703 ...
submax_watts_per_kg[0] = 10.955137252807617,10.824892044067383,10.636758804321289 ...
submax_watts[1] = 715,699,676,641,615 ...
etc.
