Running Effectiveness (kg/N): Running effectiveness is a novel metric presently unique to WKO4. It is calculated as the ratio of speed (in m/s) to power (in W/kg, or (Nm/s)/kg), resulting in the units of kg/N. It can be viewed as the inverse of the effective horizontal retarding force that a runner must overcome to achieve a particular speed. For most experienced runners, running effectiveness is typically close to 1 kg/N. Running effectiveness may be lower in novice or fatigued runners since they do not travel as fast for a given power output or must generate more power to achieve the same speed. Running effectiveness may also decline slightly at higher running speeds, when running above critical pace for example.
