No. It won’t. But you can try the manual upload: go in the riders feed in rouvy, selecting your activity, click share and then intervals.
I can’t be sure what you’re asking, but if basing on the above thread, you want to load your old rouvy data?
Seems like there’s no option to import old data from ROuvy and you have to do it manually. Hence @R2Tom’s suggestion to
There is no mass import for old activities.
To be a bit more precise with the manual upload:
You find the riders fed there
Open one if your old activities.
Click on the share button
Search the intervals icon and click share
Even my activites from 2023 are “Shared” and green on Rouvy. I’m not sure I’m willing to export all my activities manually but without them I won’t have any historic data and therefor can’t use Intervals.icu for what I was intending to. Thanks for your help, I’ll have to think about this.
have you been using strava?
if yes, you can export all history data from Strava and import it here.
Was just thinking about exporting all Virtual rides from Garmin as a csv file, would that be possible?
not as CSV…
but as FIT, tho I’m not sure if garmin has a filter to say only virtual rides…
Unfottunately no.. only TCX/FIT which are those raw files.
I think CSV only provides you with the summary data
If you have all of your history on Garmin use the “Import All Garmin Data” button in the Garmin box in /settings. If it is all on Strava do “Import All Strava Data” in the Strava box.
Yes, it is all on Garmin. I will try what you said. Will my already imported Garmin workouts be doubled?
My outdoor bike rides are already imported from Garmin right now correctly. I only want to add my Rouvy virtual rides from Garmin.
Files already on Intervals.icu from Garmin will not be duplicated.
Doesn’t seem to work with the Garmin import all data. I put the link to the zip file Garmin e-mailed me and there are no new activities in my calendar. The zip file is full of 40 folders and is about 127 Mb.
did you check if the virtual rides are there to confirm?
Did you download the zip or did you just copy the link and pasted it in the Intervals window?
It should work if you just paste the hyperlink and NOT first download.
I did not, the folder names weren’t very logical so I didn’t know what to look for.
An update. I got an e-mail from Intervals.icu that the import was completed. I didn’t realize I had to let it sit for 12h before checking if the import actually worked.
After a quick look through it seems I’ve got plenty of activities imported now. Thank you guys for helping me with this. Looking forward to diving into my new data.
Please, I need help;
i synced Rouvy and Intervals,
then i downloaded a workout from the library in Fit format. I imported it into Intervals tomorrow, but it still doesn’t appear in rouvy in the Intervals workouts section.
what am i doing wrong?
Hi I am fresh at intervals.icu and loving it, but same issue with Rouvy Sync. All connected and linked in Rouvy/Intervals but I dont have the Sync Content button
would be very helpfull to solve.
