Rouvy Integration
I have all set and i cant see my workouts…
imagem
imagem
imagem
imagem
I created a test power based workout in intervals for today but was not able to get it across to Rouvy. Then I downloaded the workout as .zwo file and imported it back into today’s activity(deleted the original file) and it works! Not sure what format the the files are created in intervals but worth a try?
All my workouts are zwo and no luck…
Same/similar here…
  1. I have not even seen the “force refresh” button anywhere :frowning:.
  2. Workout scheduled in intervals as part of the plan synced to Rouvy today.
  3. Workout in intervals calendar created “ad-hoc” does make it to Rouvy no matter how much I beg.
To add to complexity: all my workouts (plan & ad-hoc) are created in AI Endurance and are pushed to intervals calendar. But that should matter…
M.
Now it got even better :persevere:
Just went to Rouvy web to try to find the “sync now” button. I did not find it. But todays workout synced again… So now I have the same workout twice in the library.
This integration clearly requires a bit more work on Rouvy side…
I have contacted Rouvy support, had no idea this feature is so recent. So far, we have managed workouts only get synced if:
  • there’s no additional texts in description (warmup, main set 6x, etc.)
  • there’s no empty lines
  • type must be Ride and Indoor must be checked
  • Rouvy can’t “understand” ramp, range and pretty much nothing else but an exact % of FTP
An example:
It means if you have workouts that contain Main set Yx, you should copy the intervals as much as needed instead. But they said they’re working on a better sync.
Wow… Thanks. That sort of solves my headache… So at the moment the feature is more or less useless (at least for me).
I still did not find the “Sync Content” button mentioned by @david; nonetheless Rouvy imported the workout for today for the third time :sweat_smile:.
That button will be only there if you use desktop version of the app, not through web and if you succesfully synced your first workout (but that happened). Feel free to delete workouts that synced bad, because they will be there regardless of forcing sync. You probably added the entry three times in your calendar.
They wrote they will make some improvements next week. Until they fix it, all you have to do is editing your workouts to be compatible with Rouvy. I mean, it is more than nothing.
Yeah… “desktop” you mean Windows? On iPad I have not seen it. And yes, I know I can delete the workouts from the library, I was posting to show how absurd this feature is at the noment: some workouts will never sync, some will sync three times.
Anyway…my workouts are pushed to intervals from another app. Not feasible for me to edit those (changes would be lost whenever the source refreshes the data). Either Rouvy comes up with something working or…
Yes, I mean Windows, but, I guess, it should be there on MacBook, too. My goal was to sync intervals’ workouts to Rouvy, because of the routes. We’ll see if they come up with some improvements this week.
I have double outdated entries, too.
@Zoltan17 so yesterday the button showed up in the iPad app. I am not really sure why; to workout was already synced and when pressed the button it disappeared. Now let’s see when the workouts start to properly show up…
I’ve got an e-mail yesterday that they have fixed additional text issues. Now, workouts like this sync, too:
Of course, Rouvy still can’t understand ramp or range. I still have duplicated workouts, but that’s better than nothing :slight_smile:
Only some of my Rouvy activities are syncing back to Intervals.icu. Anything I can do to remedy this?
With Ride selected and Indoor checked it synced for me to. Virtual Ride doesn’t sync weirdly enough…
I don’t have a “indoor” option. Using “Ride, MTB, Virtual Ride”. There are some imported activities and they are defined as “virtual ride”. But some days are not imported from Rouvy.
There recently was a small change which could influence.
Read from here and lower:
Intervals.icu doesn’t do any filtering on the activities uploaded by Rouvy. Try download the fit file from Rouvy and upload it manually. If that doesn’t work then I need to look at the file (david@intervals.icu). If that does work then Rouvy is likely not sending it for some reason.
I sent a file from feb. 13th that didn’t upload. I did a workout this Saturday and Sunday and they loaded up just fine. I just registered here on Intervals.icu so it would be a grand job to find and manually upload any missing .fit files from Rouvy. If I need to add any other type or class to my “Ride” profile to make Rouvy workouts appear then I just need some help to get on from here.
Oh, wait. Doesn’t Rouvy send old data from before connecting to Intervals.icu?
