Rounding numbers
Hi.
In some cases the it should be useful to round the numbers for 2 or 3 decimals. It happened for me with RPE that the the site renders something like that 4.666666667. It should be much nicer solution to just show 4.667 or 4.67 and it is just one line of code change.
Best regards.
These ‘decimal issues’ did occur in other places and got handled in most cases but if you notice them elsewhere, tag @david to correct them.
this is the version I use
I just fixed this. Note you need to delete and re-add any existing RPE plots to get the change.
Here’s another instance of the ‘decimal issue’. Activity page | List view | Average row (bottom)| ‘Coasting’ field. Thanks @david
Also, what you’re doing with Intervals is brilliant, as is the community in this forum. I’ve cancelled my Strava and TP subscriptions, and am encouraging friends to do likewise.
Thanks! I just fixed that (and others using that time format).
