Road- and Maintenance-Entries
Hello,
I want to ask if there is a functionality available for a kind of Roadbook and Maintenance-Book.
When did I change a Chain?
When did I swap Tires or Wheels?
When did I get the new shoes?
And in addition to that a possibility to do stats - how long did I use a certain Chain, Wheel, Component.
is this possible? I did not find anything that caught my eye…
Setup Gear and components on the Settings page.
Thanks, @MedTechCD for pointing me in the right direction.
Unfortunately, intervals does not calculate the Usage.
I set the filters to Default gear for cycling, Gravel - set the Purchase date to July 31st - hit “Calculate” - but no values are automatically calculated.
Am I missing something?
The default gear will be applied to new activities.
For historical activities, you need to apply the gear to them retro-actively.
Open the Activity List view, filter and sort the activities, then use Edit - Edit to open up this dialog that will allow you to apply gear to older activities. Display the Gear column to check what has been done/needs to be done.
Thank you SO MUCH!! @MedTechCD
