Ride Results Showing up that are not mine. Fail to Record Heart Rate
This week: ( comparing to both Zwift information and confirmed on Strava import of same )
Sunday 08 Feb: Missing HR information??? Recovery Ride 31Km, 1h4m - avg heart 100bpm
Saturday 07 Feb: I did NOT ride at all but it shows a 19minute segment 10Km,
The list goes on and on. OKAY I discovered something weird. It would appear as though the APP is combining my rides and my wife rides on my login?? Hers, only contains her events.
Also she is not using her HRM of late, but I have for every event…
Please advise as how to only show my events, and to re-engage HRM.
Then you probably linked your wifes account into your account too.
What connections do you both use? Hard to help with no further information.
Well I dont know how to link accounts for starters? How does one link or more importantly DELINK accounts. When I log into her account, my events do not show up on her account??
We use different email accounts and passwords if that is what you are asking?
Should I just select the events that dont belong and delete them under the activities page???
Log in to your Intervals account/session and check the Settings - Connections tab. Then do the same for your wife’s Intervals account.
I, for example, have connections to Garmin Connect and Coros.
When in doubt, disconnect everything and reconnect making sure that you define your own account.
Also make sure that you both have your own proper account on the source of your activities. If you are both on Garmin Connect for example, make sure that:
  • your device is connecting to your own account and only to that one
  • you disconnect the Garmin session before flipping the Intervals account
If you both use the same computer with only one user account, then everything is in one user profile on your computer and that can become confusing. If you each have your own account on the computer, then keep things separate and don’t login to any of the sites of your spouse.
Will do wonder if the results are not leaking in from zwift directly but maybe from strava???
I checked and both accounts have not added any athletes or coaches etc.
I imagine I will have to manually delete any events on my list …
The question was, what connection do you both use. For example, share a screenshot, of that connection page like @MedTechCD did.
My guess is something like this: You both have a connection to Zwift and Strava. But you linked Strava to your wife’s Strava account.
So what connections do you (both) use? What source are the “wrong” activities coming from (see top right corner inside of an activity “~ View on Strava” or Garmin or Zwift?)?
