Reload from garmin failed
I have cropped an activity on garmin connect and try to reload it on Intervals.
I got a error “Timeout waiting for data from Garmin Connect”
I also get this error on other garmin activities.
Is it Garmin’s fault or is the problem on the intervals side?
New activities are imported/synced
I’m having the same problem.
I don’t know the reason, but Intervals.icu also doesn’t show me power data recorded with the Garmin Data field (app), even it was showing that data earlier.
The power data is visible in both, Garmin Connect and Training Peaks, but not here.
Also, when I download .fit (original) activity file from garmin, and try to upload it to Intervals.icu, nothing happens.
I downloaded your most recent file and it has “C Power” and “A Power” fields in the records. These are not currently picked up by Intervals.icu. What are they actually?
Intervals.icu ignores duplicate files and that manual download from Garmin is the same as the one already received from Garmin.
Garmin heavily restrict calls to fetch old data and reject duplicates even if new activities have appeared. So your best bet is to download the file from Garmin and manually upload it.
“C” stands for calculated, and “A” for average power.
I already used this garmin app before, for this activity Intervals.icu (15 September 2022) and as you can see it alredy showing power data.
Ah that one comes from Strava. Strava must have support for that field. So “C Power” is the one to use then?
I added support for “C Power”. You need to do Actions → Reprocess file to see it. I did that on your Friday ride to test and it works.
Thanks a lot David
I really appreciate your time and effort you put in this
Have a nice weekend
