I have added a hr strap as an equipment and would like to calculate its usage from a past date.
I have entered the date and hit calculate but nothing has happened.
Is that possible?
Tks
Is that possible?
Tks
CALCULATE
will recalculate the total time shown based on the Moving/Elapsed time toggle.
You’ll want to go into the Activities list view, select the past activities you want to set the gear in and bulk edit: EDIT → Edit → Select Gear → OK.
humm, by doing that I’m not “adding” an equipment but “changing” it …
I just want to account for the life of the HR strap and HR sensor battery.
I could make them components but not all activities have any equipment (weight, yoga, cardio).
As far as I can tell you can only have one thing set as Gear.
I’m sympathetic to this use case - I too wanted to track which runs I did with a HR strap instead of the watch’s optic sensor. I think the best current approach is to use tags…
I’m curious if/how other people are handling this.
You probably need to add your HR strap as a component to top level gear items (bikes etc.) you use it with and add another “container” HR strap gear item for Yoga etc…
