Ramp to steps when synch to Garmin
Hi David,
I’m aware of the automatic range creation when synch to Garmin but not sure about creating steps from ramps which I could use also on Rouvy (if I could download a "Garmin’s type mrc/erg file) .
Could you please confirm?
Tks,
You need to make the steps manually. Garmin has a 50 step limit for workouts so I haven’t done any automatic ramp to steps conversion.
Any way this could be looked into once again?
It would be nice when creating a workout to have a tick mark to convert ramp to steps and then a box where you can define how many steps you would want to break up the ramp(s) into.
This way you could still do some quick math and fit into the 50 limit, but not having to add 20 steps manually :slight_smile:
There is this nice little Extension “Ramp Converter” :slight_smile:
(You find it in the settings too)
https://intervalsicu.skaykand.pl/
Won’t work for me. For plannend workout it will fail with: “:cross_mark: Failed to update Planned Workouts.”
For workouts in my library: “:white_check_mark: Library Workouts updated successfully!” but it will not change anything.
