What is the “seed” of my weight data for my charts on Intervals? My Strava weight or my weight noted on my Intervals??
I’m a little confused…
The most recent one ‘sticks’.
If you set it manually on Intervals, and it comes in after from any other source that is connected and configured, that one will override.
You might be confused by the fact that some days have weight without you inputting anything. Intervals needs weight for w/kg calculations. If no weight data is found for a day with an activity, Intervals will populate the weight field with the most recent one known.
Thanks. I have my weight on my Intervals profile (I don’t add manually my weight each day on my calendar), and my Strava profile.
So intervals takes the one that was added first??
Intervals always takes the most recent one. If you change it on your profile or through a Wellness field, it doesn’t matter. It is stored with a Timestamp and the one with the most recent timestamp is used for your activities.
