May have missed this, apologies if so, but is it possible to pull the laps direct from the Strava activity if they exist?
It seems at the moment to auto-detect laps from the activity, but for a track set or similar, where you’d lap the activity, could those be pulled through directly preventing the need for the auto-detection?
There is an outstanding todo list item to remember the “use laps” option for different activity types. Right now you need to manually do that. Also Strava sometimes mangles lap data if you are using the privacy circle.
@Maarten_Aerts The “sync with Strava” button reloads the activity from Strava. You might want to do that if you edit the power and need to undo or whatever.
