I cannot see the Smo2 values with the Hummon band, despite having selected the Smo2 check mark and linked my account to Garmin Connect. thank you very much and sorry for my english
I had a look at one of your files on https://www.fitfileviewer.com:
Is “currHemoPerc” equivalent to SmO2? And “currHemoConc” to THb? It would seem so from the units. If so I can easily import those as SmO2 and THb and things will work.
Ok I have added these, will deploy Thurs AM (GMT+2).
It’s live now. You need to go to “Actions → Reprocess File” on older activities to get the new traces. There is also a bug thats stops them from showing up immediately after re-processing … reload the page to fix. I will sort that out tonight.
Thank you so much, I answer only now that I had some problems with the computer, thanks again I will also try to reprocess the files
