Problem with HR zones in workout editor
By using the workout editor, when I add a step with the HR zone, the low-top range bpm calculated by the editor doesn´t match the HR zones defined in my settings.
Example:
Is it a bug ? Or it’s me who is writing the workout steps the wrong way ?
I see the same when I copy/paste your workout. There seems to be a shift in %.
On the other hand, the absolute HR values are correct.
Please check if you’re using Threshold or Max HR
By writing Z2 Z2 HR you are creating a workout on power. If you want HR on its own then you must only show Z2 HR.
If I create a workout and look at my HR, it matches my zones exactly; at least the bpm range (111-127).
