I have 2 years of data in Intervals.icu - all cycling.
My Power curves will only include data from before 10 March 2024 - after that the Power curve says there is “No matching activities with power found”.
When I look at the individual Activities, my ride on 10.3.24 shows tabs for Timeline - Power - HR - Data.
The ride on 11.3.24 does not have the Power tab, and a pop up appears saying “Curve not found”. But the power data is there. Between 11.3.24 to today - it will not load/use (?) the power data.
See screen shots below.
What do I need to do to get this power data in or coupled? etc? I’m using exactly the same bike, garmin head unit, power metre etc - it just stops coupling the power within intervals on 11.3.24?
Hi, not sure how to explain this. I ride with a power meter and my data in Wahoo and Strava show power. Now there is no power info in my last rides.
Intervals showed my morning ride with power and even calculated a. New FTP. Neither appears anymore. I have not changed any settings. Ideas?
I wonder if this has got to do w/ the new feature and rides are marked as Commutes? (when it’s marked as Commute, the Skyline chart will not be shown, hence the cloured Bar)
Thanks both.
I think it is ‘fixed’ by doing the following:
Settings - Power Settings - entering a value against FTP and then under the ride clicking ‘update activities’. It then updated every activity I had done.
