I ask if there is the possibility to adjust the power data of some activities in percentage for all the acticity.
I mean, if I have used a power meter with 5% difference of the power meter that I use normally, can I modify all the power data of the activity in percentage, in order to have the data comparable and to have power curves corrected and adjusted? Thanks.
That would be a great feature as is would negate the need to us fitfiletools and all the deleting and reloading files
You can do that already. Click “Fix data” under the ride timeline chart and use the scale and offset. Here I have chosen 0.95 for scale so the power will be reduced by 5%.
GREAT! Thanks very much!
