…for exactly the reasons you mention, except my altitude hit is around ~15%! (2500m to sea level) and it makes my charts pretty difficult to interpret that’s for sure
That’s a good idea but quite tricky to get done. The power-duration and other related curves (power vs HR) are computed for each activity and stored. So I need to store a whole new set of altitude adjusted curves. I have added this to the todo list.
One thing maybe worth noting is that the actions->fix data->altitude offset change is always applied after activity initial processing so the ability to reprocess whatever is precomputed, ideally in a batch would be great. I can theory craft features for others to implement all day long tho of course. Thanks for even considering this
I know this probably isn’t the intended use of this feature (also googling and searching the forms I havnt found anything) – but I am going to be at 7k feet/ 2100m the next month or so and wondering if there is a way I can override the altitude from zwift to use something like this so I can compare to my otherrides while I am back at sealevel?
Okay, digging this one up once again…
I’m trying to add the altitude corrected power values to the activity summary (like “normalized power alt.” and “average power alt”) but these fields seem to missing for the summary?
Am I missing something here? If not, can these fields please be added to the activity summary?
Thanks @R2Tom , I’ve added your fields.
For anyone trying to this: go to Settings>Sport Settings and add R2Tom’s custom fields. Then go to the activity and choose Actions > Edit Summary. Edit the panel and add the custom fields you’ve just added under Sport Settings. The final step is re-analyzing the activity for the custom fields to be populated (Actions > Analyse)
