Planned workout re-uploaded to COROS after activity sync, breaking COROS plan-activity link
Hi David,
I create planned workouts in intervals.icu via the API (events/bulk?upsert=true, with external_id) and they sync to my COROS calendar. I run them from the COROS watch’s training schedule, so COROS links the activity to the plan and shows step completion on the calendar card.
Problem: after the activity syncs, the planned workout seems to be re-uploaded to COROS even though nothing changed. COROS then recreates the plan with new step IDs, so the link to the completed activity is lost (step completion shows 0%, though the day still counts as “completed”).
Example on 2026-11-18 (KST, UTC+9), Ride “수영장 왕복 자전거 6km” (external_id sheet-20261118-ride-commute):
  • 09:50 workout created via API, synced to COROS (plan version 1)
  • Watch synced, workout started from the watch schedule
  • 19:32-21:27 ride recorded (5.26 km)
  • ~21:50 phone synced, activity uploaded to COROS, then to intervals.icu
  • 21:51 the COROS plan for this workout was recreated (now version 3, new step IDs)
My script made no API calls at that time (logs confirm 0 events sent since 10:00). In intervals.icu, the ride was NOT paired with the planned workout. A run on the same morning WAS paired, and its COROS plan was not recreated after the activity synced.
Questions:
  1. Does intervals.icu re-upload planned workouts to COROS when a new activity is received (e.g. for unpaired workouts on that day)?
  2. Is there a setting to stop re-uploading a workout that hasn’t changed, or to stop syncing workouts for today and past days?
  3. Why might the ride not have been auto-paired (planned 18:00 / 6 km, actual 19:32 / 5.26 km)?
Because the Load planned was to different from the Load done. To pair automatically, the load done must be within 50-150% of the load planned.
Thanks for the explanation — that matches what I see. I checked all my workouts from 11/3 to 11/18: every activity whose load was within 50–150% of the planned load was auto-paired in intervals.icu, and the one ride outside that range (167%) was not. So pairing on the intervals.icu side works as expected.
The remaining problem is on the COROS side. Independently of the intervals.icu pairing, the COROS training calendar does not show step completion for most of these workouts, even though every one was started from the COROS watch’s training schedule.
  • Normal (11/5): paired in intervals.icu (133%) → COROS calendar shows step completion (blue bar)
  • Abnormal (11/7): paired in intervals.icu (143%) → COROS calendar shows 0% step completion (grey)
(screenshots attached)
From COROS Training Hub data, every grey case has one thing in common: the COROS plan was recreated (new version, new step IDs) shortly before, during, or after the workout. For example, the 11/7 plan was recreated at 04:57 KST and the run started at 07:21. This morning, two unchanged future workouts (11/23, 11/24) were also recreated at exactly the same second, 04:09:29 KST. My script sent nothing to intervals.icu at those times (logs show 0 events sent).
Do you know what could cause this? In particular:
  1. Does intervals.icu re-send planned workouts to COROS on a schedule (e.g. a nightly sync around 04:00–05:00 KST) or when activities are synced, even if the workout hasn’t changed?
  2. If so, is there a way to avoid re-sending unchanged workouts, or workouts for today and past days?
Thanks again!
