Hi all, looking for help with a Garmin sync issue that a clean disconnect/reconnect doesn’t fix.
Athlete: i290753
Symptom
Planned events on my calendar do not get external_id populated. Activities recorded against those workouts come back with paired_event_id: null and don’t auto-pair, even though my watch (Garmin Enduro 3) loaded and executed the structured workout correctly — laps match the planned step boundaries to the second.
So I’m in a half-broken state:
- Workouts reach my Garmin Connect calendar (visually confirmed there)
- Watch downloads structured workouts and executes them with correct lap structure
- Activity comes back to Intervals with the planned workout’s name (sometimes truncated, sometimes with a "City - " location prefix added by Garmin Connect)
- But on the Intervals side, every planned event has
external_id: null,oauth_client_id: null,paired_activity_id: null - And every resulting activity has
So the workout reaches the watch, but Intervals never records the Garmin workout ID back, leaving no shared key for auto-pair. I have to manually pair every run.
What I’ve tried
- Disconnected Garmin in Intervals → Settings → Connections (unlink icon)
- Removed Intervals from Garmin Connect → Profile → Settings → Account Information → Connected Apps
- Reconnected from Intervals → Connections → “Connect Garmin”, confirmed “Upload planned workouts” is enabled
- Edited an existing planned event via the Intervals web UI (added text to the description, saved) to try to force a re-push
What happened after step 4
The event’s updated timestamp moves, but:
external_id: still nulloauth_client_id: still nullpush_errors: still null (no error logged — silent skip)paired_activity_id: still null
So the integration thinks it has nothing to push. There’s no failure being recorded; the push pipeline just doesn’t fire. Same behavior whether I edit via the web UI or via the API, so it’s not a client-side issue.
Side observation (possibly separate bug)
Editing a pace-zone workout appears to convert the step targets from pace_zone to power_zone on save, even though my Sport Settings → Run → Workout Zones Priority is set to “Pace, HR, Power” (Pace first across all four columns: Training Load, Time In Zones, Workouts, Intervals).
Before edit:
"steps": [
{ "pace": {"units": "pace_zone", "value": 1}, "distance": 4000 },
After edit (workout_doc not touched in the request):
"steps": [
{ "power": {"units": "power_zone", "value": 1}, "distance": 4023.35, "duration": 1262 },
This reproduces with both UI and API edits. Not sure if it’s related to the push issue, but flagging in case it is.
Possibly related threads
- Intervals.icu not pushing planned workouts to Garmin Connect App (Jan 2025)
- No synchronisation with Garmin Connect (May 2026)
Happy to provide event IDs, activity IDs, or run additional tests. Thanks!
