Perceived Effort Metric not syncing from Garmin
I have “Run” activities with a Perceived Effort and evaluation in my Garmin run. When synced to Intervals.icu it shows the RPE as unknown. Is there a way to get this metric synced as well?
If you get the RPE question at the end of the activity and you provide RPE at the time of closing the activity, the RPE is in the FIT file and should be acknowledged by Intervals.
If you enter RPE later on in Garmin Connect (thus not on your devce), it will not sync to Intervals.
The reason is that Intervals only get’s the FIT file and there are limited sync possibilities with other Garmin Connect data.
an alternative if you’re on iOS is to use BreakAway: Indoor Training to add your RPE after the fact and have the info updated in Garmin + Strava + intervals all 1 go.
