Pairing TrainerDay and Garmin Activities
Hello,
I’m wondering about why my two activity files didn’t pair this morning. This is the first time I tried to record this way so let me describe it.
I recorded a ride in TrainerDay and used TD to control Zwift. TD sent the file to Dropbox where Intervals picked it up no problem.
To get speed and elevation, I recorded the ride in Zwift and had RunGap send it to GarminConnect. GC sends to Intervals - the second file. (This is my normal approach when I don’t use TD to control the trainer).
I now have two activities for today. I was hoping that they would be close enough to get paired into one activity.
Thoughts?
Thanks, Mark
Activity files will not pair. You can pair a scheduled workout with a performed activity but pairing 2 activity files with all the different traces and metrics can’t be done in Intervals. It’s a complex task to merge 2 files with multiple streams that need to be synched.
This tool will do that: (one time donation needed for saving FIT files)
https://gotoes.org/strava/Combine_GPX_TCX_FIT_Files.php
That makes sense. Thanks for clarifying and confirming. It sounds like the easiest route would be to just add the speed and elevation data manually to the TD/Dropbox file.
