Outdoor power Rande doesn’t work anymore since around a week on Garmin for biking.
In the training activity I have set the power range from 132-143w.
After syncing to the Garmin device it shows the same values and not the adjusted with 5% anymore.
Did try to adjust the outdoor power range to 9% but the result is the same.
It is not checked as indoor activity.
Unfortunately the indoor checkmark is only visible in the editing mode or is there a other possibility to see which training activities are marked as indoor?
Best
Not 100% sure because never used it like that (with a range), but isn’t the purpose of this setting not to convert fixed values to a range by adding/subtracting this percentage from it?
100 becomes 95-105
While defined ranges in the workout remain as is? 98-102 remains 98-102?
In my opinion, it worked with ranges in the past as well.
I have no idea how I could verify that now, after the fact.
I encountered this same issue today, where the workout had fixed percentages set. I checked some of my previous workouts, though, and there were no such issues. The difference was that this particular workout was marked as “indoor,” whereas the previous ones which didn’t cause any problems did not have that box checked in the workout file in library. I’ll need to verify this next time.
Then there is no issue on your side because the fixed percentages only are converted to a range for Outdoor workouts. As the setting explicitly is named ‘Outdoor power range’.
