Some activities are not syncing. It only syncs my commutes atm, i havent changed any setting, anyone know why?
What source are you syncing from?
Did you check if the activities are also missing in the Calendar List view?
Check the Strava connection to see if something inadvertently got enabled/disabled. I can’t tell you exactly what because I never used Strava, but first impression is that some sort of filter is active in the connection.
Did you enable Wahoo import in settings (I would recommend using this)?
Are they deleted? (Check Options > Deleted to show deleted activities)
