No synchronization of fitness data from Dropbox
Today’s morning I noticed a problem with the synchronization of “interval.ic from Dropbox” in terms of fitness data.
Interval.icu does not download this data:/
Formal synchronization from Dropbox works because training is updated.
Downloading fitness data does not work :frowning:
@david, can you look if you can fall apart as possible?
regards
Artur
I have the same problem
Also had the problem, so deleted the linked file and relinked it to get it working.
I did a clean up and deleted all files from Dropbox and then sent again from HRV4Training but even thought I have no data from todays at Intervals.
Ok,
I had to delete and resync the file at Interval’s dropbox config and not at Dropbox itself.
There was an issue with delivery of webhooks to Intervals.icu starting sometime yesterday and resolved a few minutes ago. That would cause new files to fail to sync automatically.
