No Press Lab Suunto Vertical
hi team,
Today my SV, when doing a planned workout with Intervals, has been going from interval to interval without respecting the “Press Lap”. It’s strange, because it’s a workout that I’ve done several times and I don’t go through the interval until I press the button.
So “press lap” was working but it isn’t now? I made a change to that code a few days ago to try fix another problem. If you confirm this I will revert that change. My wife has a Suunto but she is away at the moment so I can’t test on a real device.
Hello,
Yes, since last Friday, “Press Lap” does not work on my Suunto Vertical.
I’ll show you a video where you can see the error: WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
Thanks for your help.
I have rolled back that change. Your workouts should update in the next 12h or so. You can make an edit to a workout to force and immediate update. Please let me know if this fixes the issue.
Solved. I created a new activity and it worked correctly.
Greetings
Hi Team, I have tested on Friday with a Suunto Vertical and the press lap does not work. I have checked with other people with other watch and works fine. Any update of this ?
Do you mean that other Suunto watches work?
Hi , only fails on Vertical y S9pp. I have the confirmation in the Suunto Forum.
Have they said anything about if/when it might be fixed? Intervals.icu sends exactly the same data to Suunto, it doesn’t know anything about the device.
In this case, it is likely to be because of Suunto, in a few days a new software update will arrive from the watches. When it does, I will let you know.
Thank you very much
In my Vertical Suunto, Press Lap works correctly. Be sure to select the guide manually before starting the activity. Greetings
Can you send me a example please, to test it.
Hola,
When you start an activity and have a guide planned, the watch asks you if you want to do it. You have to select “no”.
Next, go to activity settings, Guides and select the one you want to do. You can start the activity now.
Excuse me, but I don’t speak English very well. I hope I have helped you. Regards.
Gracias :wink:
Now works for mi select no and later chosee the guides.
Thanks a lot.
