No Garmin history
So I joined intervals icu a couple of days ago. I connected my Garmin account. All data was showing. I then adding my Strava account. On doing this, I realised that some workouts were duplicated and shwoing twice as i will sometimes use my Garmin device to record a workout when also riding on say Zwift or TrainerRoad. So deleted my intervals icu account and started again, this time only connecting my Garmin account. I went through the usual process of granting intervals icu access to my Garmin account etc.
However, now, there are no activities showing on intervals icu.
Help!
Unfortunately Garmin are very strict with calls to load old data and do not allow duplicates. I don’t know how long they keep that history for. Your best bet is to use the “Import all Garmin data” button in the Garmin box in /settings. That gets everything.
Re the duplicates that shouldn’t happen. Intervals.icu deletes Strava activities when matching activities come in from Garmin or elsewhere. Note that for Zwift you need to stay connected to Strava. Intervals.icu cannot get those from Garmin Connect.
Hi - I possibly didn’t make my question clear. When I originally set up my account, all the data (from Garmin) was there. I had only linked my Garmin account. I then (foolishly) linked my Strava account. I will sometimes ride on TrainerRoad whilst at the same time riding on Zwift. When doing this, I record the activity on my Garmin 945. That device is linked to Strava.
After linking my Strava account to intervals icu, all of my activities were showing but there were ones from all platforms. This happens on Strava too. So for example, a TrainerRoad workout I would do called “Volunteer” appears as that name on Strava (as it did on intervals icu), on Garmin Connect too. My watch records this as “indoor cycling”. On intervals icu all were showing.
I then deleted my icu account and started again, this time only connecting my Garmin account. Since doing that there is no activity history.
It might be simpler if there is an issue with Garmin now not pushing that data through to just link my Strava account. But this will I am sure show the duplicates as mentioned above.
