Message Notification Won't Go Away
I keep seeing message notifications from one of my athletes. The notification persists after I read a message, or in some cases I get a notification when there is no message. This only seems to be an issue with one of my athletes and it works exactly as it should for all the others. I’m currently seeing 2 notifications from this athlete and there are no messages from him.
I also see a “stuck” notification for a message on one activity. All other messages seem to get marked as read correctly.
Specifically, I see one unread message from my coach (not Chris) and the green bubble with “1” just doesn’t want to go away. It’s been there since Jan 11th.
I have fixed this. Tx. Those messages were on deleted activities. Those no longer count and it should be much harder to add a message to a deleted activity now.
Thank you!
Out of curiosity (I’m a software guy), was the fix a manual intervention by flipping a bit in the database or a bugfix in the software?
Either way, thanks!
No I fixed a bug in logic I wrote many years ago to not send back “seen message” sometimes. Can’t figure out why I did that in the first place :slight_smile: so hopefully it is all ok!
Heh, the far too common “what was I thinking all those years ago?!” :smiley:
To say it explicitly, the the stuck “1” bubble finally disappeared. Thanks again for the fix.
