Hi there, is there any possibility to get a workout I marked as done to strava. I’ve done that workout but had no possibility to get the live data from the indoor trainer I used on vacation. I already tried to download it as fit file from the activities list, but that does not work.
mark as done is just a flag. It doesn’t do anything else.
you can just input a Manual Entry in strava.
Ok, but is it intended that when I select multiple workouts in the activities list and try to download it as zip it is not working at all when there is one or more of the workouts marked as done? Seems like a bug. And I thought it would be nice if there where a possibility to convert such workouts to a uploadable fit file so you would have the power data from the workout
Is this a request to download a completed workout as a FIT file? (one that was recorded and has live data)
Yes that is the Edit > Download fit files. But when there is only one file in it that is not a recorded one it fails.
Ah… Yes… that it does…
Time to File a Bug Report to David
@david - per above, a manually recorded (Mark as done) workout, when downloaded together w/ some other recorded data workouts, the download will be successful, but the resultant ZIP file will be unable to be opened. (ZIP error)
Ok, thanks. But would be nice if it where possible to convert some manual workouts to legit fit files in case you are not able to record it
I have fixed this. You can’t download a fit file for a manual workout but it will no longer break the whole zip. Will deploy Friday AM.
Ok, thanks
