Locating peak power
On my steady Zone 2 ride today, my Garmin has logged a peak power of 1085 watts, which is by far my best ever, so given the way I rode, I assume that it’s an error.
I have been looking at the time line for the activity and cannot locate the measurement - is there some trick to search for this, so I can see where exactly the Garmin had this hick-up?
Also: Is there some way I can tell intervals to ignore the peak value from the ride? I don’t really want it to show me a peak power, I know I didn’t do…
I located it by adding the max power column to the list of intervals, so I could see which interval it was in and then zoom in.
It happened while I was stationary to fix a puncture, so probably a bump to the pedal when I turned the bike upside down or something.
But anyway, now I have it on the timeline - can I tell intervals to ignore it?
You can ignore with Actions - Ignore part. First zoom into the specific part.
Or, in this case, it might be a better idea to modify the stream with Actions - Edit Data
Thaks - edit data was perfect here!
