L/R pedal power
I recently switched from a single crank power meter to power meter pedals.
They connect fine to my Garmin and Garmin Connect gives me all the left right stats etc.
Strava of course doesn’t as it just takes power as one reading.
I used to feed Strava into Intervals.icu but I have since changed to only Garmin feeding in the hope that it’s more comprehensive stats would filter in.
Is there a way of getting the individual pedal power stats into Intervals.icu.
Cannot see how to but I could easily be missing the trick.
thanks
just connect directly w/ GC. (which you’re alry doing now)
Yep, connect to Garmin Connect. Intervals is pretty good at detecting duplicates and seems to take the interesting data from Strava (better ride title) while taking the more complete data (like L/R balance) from Garmin.
I believe. If you change the title on Garmin. It will propagate here. (New feature here)
is there a special sauce to get this going?
checked /SETTINGS and don’t see an option there
I just changed the name on Garmin Connect (and desc) and nothing has happened. (clicking on the Garmin link in the activity timeline will bring me to GC’s website and I can see the name there, but it’s not reflected here)
If I remember correctly, Garmin connection refreshes only a couple of times per day and can’t be triggered.
Wait till tomorrow to make sure if it works or not.
