kCal Consumed from Garmin Connect
Hi there,
I’ve seen it discussed before, but I’m not able to find a workaround for this.
I’m uploading consumed calories from MyFitnessPal to Garmin Connect successfully, but not from Garmin Connect to Intervals.icu. It used to work till last June, then it synced no more.
Apparently I’ve got everything correctly set up: Garmin, Wellness, kCal links enabled…
Any suggestions?
Riccardo
Garmin no longer sends 3rd party data; only data that is recorded on a Garmin device.
Understood, thanks!
Is there any workaround for this? Through another app maybe?
Riccardo
I don’t use the app, so not 100% sure, but should work using Google Fit and/or Apple Health.
Thanks again!
Riccardo
Hello @david! Now in garmin connection menu appear kcal, why not sync with intervals?
Do you use a Garmin device to record the activity?
