Issues detecting activity laps
Hey David,
This is the first time the system is not able to detect the intervals from the laps of my Wahoo Elemnt Bolt unit (Intervals.icu).
Strava detects the laps correctly, so it shouldn’t be an issue with the activity fit file.
Any idea?
if it’s an activity that already has built in laps supports, then I suggest that you turn on “use laps” instead of relying on intervals to find the laps.
search the forum for a thread on “use laps” i’ve got a guide written before
That’s what i did, but intervals does not detect all of the laps
@david
Tagging david for you
if you did that, intervals would NOT detect any laps, It would/should use all the laps data that’s in your FIT file.
either that or my understanding of “what you did” is different from what i think you did. (use laps) that is
You can try Actions → Analyse and tick the “keep all laps” box. Otherwise laps that look “too easy” to be intervals are removed.
That worked!
Thanks @david
