Pity.
I have space for 3 on my FR, which is a much older device (2016), so strange that a newer model would only have two.
Pity.
Check what the limitations is. You can add more then 2, I’m sure.
But the limitation is probably displaying more then 2 on the same page. Add a page in the same profile to display it on another page.
It’s a memory problem that limits the number of ConnectIQ fields that can be loaded on the device, and nothing to do with the display of data fields. Fenix and Edge models allow more.
Sadly that is correct. I bumped into that problem too and adding another screen of datafields doesn’t help. You can have N loaded on the watch but only use 2 per activity. But as Gerald says, you’d think the 955 would support at least one more than my old 935!!
