Hi
Following an issue with Bryton active this weekend I’ve ended up with an activity stuck in my device which won’t sync and upload.
I have power and HR data and all the other metrics visible on the device for the ride, is there a way of manually sending it to intervals?
I did connect the device (rider s500) to my computer but the files are in a .ubx format which Strava won’t accept
It’s only one ride but I’d like to save the data if possible.
Any ideas greatly appreciated.
Click/Tap on the date, Add Ride, choose ‘Manual Activity’ as category. You can specify Distance, Duration and Load.
Thanks, I did try this and get an error each time
“JSON parse error”
I’ve no idea what this means though.
Are you trying to attach/import your ride file or are you simply adding Distance/Duration/Load?
You can’t attach/import ride data this way.
Just trying to manually add the mileage, load and time in.
Have you tried opening it in a text editor?
It might be possible to export/save it as a csv, and then converting it to a FIT-file using Combine FIT, GPX, CSV or TCX files for Garmin or Strava. Merge Heart Rate Power and GPS
Can you show a screenshot of what you’re trying to add manually?
Might be a syntax error?
first time I’ve heard about this format. Seems to be GPS data. May not even be the full data of the ride.
