Intervals.icu and Zwift Integration is live!
Does it depend on whether or not you’re in Erg Mode?
I do all workouts in Erg mode
A question for those already using Intervals-made workouts on Zwift: what do you use as the activity title? If it’s something like, say, ‘VO2 intervals,’ how do you know the scheduled date for that workout (on Zwift)? Does the date show up in Zwift?
I’d love it if the Intervals workout builder could automatically assign a title based on the planned date for sessions created with a blank title. It would make things much easier when I move workouts around on the calendar (a bit off-topic, but relevant to the Zwift issue) :grinning:
That feature is shown by setting the attribute show_avg="1" on the intervals (Ramp, FreeRide or SteadyState). Zwift’s new API has some (arguably overly) strict validation for workouts, and it’s likely that it doesn’t accept this attribute and David had to remove it - even though it would be understood by Zwift.
This is indeed great, but I can’t wait till the settings are syncable. I’d love my weight to go from intervals to zwift automatically
Could also use this very mini site I made years ago
http://cubingtest.byethost9.com/Other/CyclingCalculator.html?i=1
To copy the tables from https://whatsonzwift.com/
Connected directly and disconnected Strava.
You can publish my data without restriction.
Unfortunately the Zwift API does not support the show_avg attribute so I had to leave that out. I have asked if it could be added.
The Zwift home screen shows the workout(s) scheduled for today. If I encode the date in the name of the workout it will end up in the name of the completed activity which isn’t good.
I have asked Zwift about this. Currently there isn’t an API endpoint to do that.
Nice article on Zwift Insider:
https://zwiftinsider.com/intervals-integration/
Thanks for the integration, it works great! :+1:
Thank you very much. This is something I have been Waiting for so Long.
When I turn on zwift integration I get duplicate rides (one from zwift with correct title, one from my other integrations with generic title)
Intervals.icu will de-dup Zwift rides against Strava (it deletes the Strava one) but cannot choose for other services. I suggest not downloading “Virtual Ride”'s from your other integrations. Just click “All activities” in the appropriate box in /settings and select the activity types, excluding “Virtual Ride”.
What happens in this case if nothing is done?
Then you need to manually delete one of the dups.
This now means I am officially off of using Strava as the source of any of my workouts! :slight_smile: Thank you!
Amazing, thank you for this! I don’t need to manually export and upload activities like an animal anymore
Zwift sync party? Not on our guest list. FTP chaos incoming.
Wahou ! it’s marvelous : it’s Christmas before the time! :christmas_tree::gift: Thanks :heart:
Well done! I am using Garmin and Zwift for recording my rides. But would like to keep the master/consolidated record of all rides on Strava. With this integration can I still use Strava as master and only import todays workouts to Zwift?
