Interval editing updates
Interval editing now uses a floating toolbar (click on header to open) and you can see changes on the chart before saving them. You can still drag the edges of intervals on the chart to edit.
You can edit any of the fields. The arrows to the right of the label shift the interval left or right. The resize icon selects the whole activity:
The split button breaks the interval into pieces:
The climb in thirds:
Here I have split the whole activity into 5km intervals with a short one at the end:
Excellent! I was able to recreate in a minute what I had to labor over before
Thanks, David!
How about a line/field to enter the times/distances like in runalyze.comScreenshot 2022-05-06 120035, so different Intervalls can easy entered. like the 5 min warmup, 5x speed, rest,… etc.
So the intervals are just generated from that input one after the other?
jep, 1st the intervalls are regular calculated, but in the workout you can analyze it and it’s possible to enter a distance, time or pace
You enter a new one for every interval or different for each
Editing finished Workouts or also planned?
Bcs right now for planned ones a new step is just simply added to the end
I intended to make it possible to edit workout steps using the “Add Step” form but dropped that idea. It is tricky to do and once you get the hang of the syntax a little using the “Add Step” form it’s easier to just edit the text.
