Integration with TrainAsOne
Would it be possible to have better integration with TrainAsOne? I cannot find if they have an API. I have created a webcal on TAO, and added that to Intervals.icu. Here is an example of a future workout:
Economy run 48C (adjusted for 21.8℃ and 1.57 undulation)
Total: 12 minutes (~1.7 km)
Run steps:
  • Walk/slow run for 5 minutes at 07:20/km 132 bpm (125 to 139), (682 m).
  • Easy run for 7 minutes at 06:36/km 145 bpm (136 to 154), (1.1 km).
Would it be possible to analyse that and automatically create a workout with the correct steps?
Currently, past workouts do not include run steps, however TAO may change that.
I have mailed them re API access. Parsing text like that is brittle … if they make any changes it will break.
Thanks for looking into it. I’m interested to find out what they say :slight_smile: .
Hey @david, did trainasone.com respond?
Yes they did and this is on the todo list.
I know this has sat dormant for a year, but I wanted to chime in just to say that it is something I would also be interested in (assuming TrainAsOne does what’s needed on their end).
Hi, I am curious whether there are plans to work on the integration with TrainAsOne. Automatic sync of planned runs would be great!
Has there been any changes on that topic? It would be really cool to see my planned workouts from TrainAsOne in intervals.icu
I’d also love to see this added. For me it would be totally worth upgrading to a paid tier.
Hi, I’ve coded a script that transforms the TrainAsOne calendar to Intervals.icu format.
You have to:
  • get your TrainAsOne calendar ID: in the calendar view of the web app, select “calendar sharing” and copy the ID (e.g.: the id is ‘abc’ if the url is webcal://beta.trainasone.com/calendar/abc.ics)
  • in Intervals.icu, in the Activities view, click on “Options”, then “Add Calendar”. Paste the URL https://poirelpa.whf.bz/tao2icu?id=abc , replacing ‘abc’ with your own trainAsOne calendar Id.
This is only a prototype that seems to work for me. If it does not work for you, please send me your calendar Id and I will check it.
The code is here if you want to check it: GitHub - poirelpa/tao2icu · GitHub
I tried it and it timed out. :slightly_smiling_face:
It would be nice to be able to see my upcoming workouts on my TRMNL (which I would need to code, but I’ve adapted some code from a different forum.intervals.icu thread).
