Incyclist is a free and open source Indoor Cycling App. It allows users to ride in real worlds (videos or GPX using street view, satellite view or map) and perform structured workouts.
Now the activities from Incyclist can be uploaded to intervals.icu.
Incyclist runs on Windows,Mac and Linux and supports connecting your trainer and sensors via ANT+, BLE and Direct Connect.
Android and IOS support is the next bigger item on the roadmap. However, I need to perform a bit of cleanup before I can start on this. So I expect this to be ready later this year (goal is at start of autumn season )
I need to experiment a bit with the available frameworks. I want to avoid that I have to maintain multiple code basis ( PC, mobile, TV). So I need to find a solution, where I can render my App on all three platforms
The app itself is web based - I only need to integrate with native code to access file system, BLE, ANT+,…
how can I see the scheduled workouts in Intervals in Incyclist? I can’t find them. For now, I’m downloading the workout and importing it manually into Incyclist.
But I’m working on an integration with intervals.icu (and other apps) that would allow you to schedule the workout in e.g. intervals.icu.
The idea is that I will show the workouts planned for the current week (or next 7 days), having the workout scheduled for the current day pre-selected. You still would be able to chose a different workout (in case you want to change/adjust plan).
You can now see the scheduled workouts in Incyclist. At launch time, Incyclist will retrieve the scheduled workouts from intervals.icu and will show them at the top of the workouts list (under “Scheduled workouts”).
If a workout is scheduled for the current day, the app will pre-select this workout. In case you changed your plan, just unselect or select a different workout.
At runtime , the app will check every 5 minutes for updates on the scheduled workouts.
I still need to optimize this a bit, e.g. to store the data locally, so that even in poor/no network scenarios, you would still see the scheduled workouts.
But in 90% of all cases, the feature should be working fine
