Tx for the detailed report. I have fixed this. It was using the step duration (20s) instead of the MMP duration to calc the power. Was also broken for MRC and ERG download.
There is another bug that I will fix tonight: It uses your power model even if you are downloading the file from a workout on another athlete’s calendar or while looking at another athlete.
Hi David, I experience the same using % of FTP. Both in ICU and Zwift my setting of FTP is exactly the same. Instead of 73% of FTP, that I set in ICU (see my workout today), Zwift used or interpreted the zwo file that I exported with ICU with 70% instead of 73%. Do you have any ideas?
I juts had a look at that and the .zwo file is generated with the correct % so I don’t know why it isn’t working in Zwift. You can open .zwo files in a text editor to check them:
