Incomplete sync from Garmin Connect
Hi. I just joined. I have connected my Garmin Connect account to syn the last 12 months but for some reason it stops at September last year. I have tried to manually upload the zip file of my past data but the file is too large.
How can I get all my previous 12 months of data across?
if you’re getting the archive from Garmin, they will have link as well (the link you downlaoded the archive).
use that link instead of uploading the ZIP. This way, intervals will just use the link and grab the file itself
Check the Garmin section in the linked post.
I have both Garmin and Strava activities enabled, how do i import activities from Garmin, so it has teh data to be able to use the intervals api? on intervals api, no data from strava is shared, only non-strava… I have boht enabled, and would like to overwrite the strava with garmin, but ‘import all data from garmin’ does not overwrite the historical data, the past activities remain ‘strava only’
This should not be possible. The Garmin archive should overwrite all the strava ones. Are you seeing duplicate garmin + strava entries? If you do not see any Garmin ones, I suspect that the archive may either not be imported or Garmin didn’t provide the full data or something happened in the process.
I spoke too soon… it completed now, and now, i have hundreds of duplicates :frowning:
Any tips on how to dedup intervals.icu?
there technically shouldn’t be duplicates, but this may be due to how Garmin is now NOT giving the actual FIT file. (I’ve yet to provide the details of my own issue to david, but that’s another situation)
for you, go to Calendar but swtich to the LIST view and add a source category. Then you can filter it by “strava”
