Yesterday’s training (recorded with my Garmin 820) had wrong altitudes, the training was already uploaded to Strava and intervals.icu. I tried to fix the problem on intervals.icu, but that did not work.
So I fixed it on Strava, deleted the activity on intervals.icu and tried the “Download old data” option.
In the past this worked perfectly, I tried yesterday and today, but the activity does not appear on the list. Is there a way to get this fixed? Thanks in advance!
You need to ‘Undelete’ iso download old data.
Go to activity List View and select the ‘Deleted’ filter. Then select the activity, edit, undelete.
Was there an easier way to update the activity with the corrected altitudes? I first tried to “Download old data” for 2024-3-24, but that didn’t change the activity in intervals.icu.
Anyway, won’t happen anymore, I changed the altitude settings in my Garmin 820.
I’m not using Strava myself but I’m pretty sure that ‘Reprocess original file’ after modifying on the Strava side, should get you the same result.
