Import strava description to intervals for activities
Hello, apologies if this has been requested before but a Google didn’t find anything.
I often add extra information such as sets and reps, terrain etc to my activity description in strava (not the title). It would be good if this could be imported to intervals.icu.
The problem with description is that Strava doesn’t send Intervals.icu an update when it changes. So when the activity is first synced the description comes through but that is likely before you have had a chance to edit it. So then it is out of date. And its expensive in terms of limited Strava API calls to poll for changes.
Hello David, that’s a shame that the Strava API is so limited. I doubt they have much incentive to update it either, unfortunately. Thank you for looking at this request.
Hi David,
is there a way to manually “bulk update” description from Strava?
I have for some activity an activityFix rule that kicks in after intervals download the activity and I would like to update some of my rides.
I can (for example) set/unset the commute or race flags and this will update the description as well but manually doing it one by one is quite time consuming.
thanks!
