I have some athletes who uses Bryton = no garmin connect and the dont use STRAVA either is it possible to have import from the Bryton App in some way?
AFAIK, there is no services which integrates with Bryton except for Strava and maybe TP. and there doesn’t seem to be an API either.
Buenos días quisiera saber si INTERVALS.ICU, se puede conectar con BRYTON, al igual que otras aplicaciones como por ejemplo Garmin, si es afirmativa la respuesta, me podéis indicar como realizarlo? en caso negativo que otra opción hay?
Now relive, ride with GPS and komoot are implemented as third party websites. Maybe we can ask to join
I found this website? Don’t you think that it could be possible to get the API from there?
I don’t know anything about technology but maybe it’s possible, right?
check out the pricing. Then factor in that there are 3 unique Bryton users (at least on this thread) and ~600 (random) views.
Likely need to get more users and requests.
Alternatively, you could petition for Bryton to expand their API, it took zwift > 9 years before an API opened up and that was tons of requests.
Thank you for your reply. I sent an email to support@brytonsport.com , if anyone else want to send another request asking for an API integration would be great. The more request the more possibilities to get implemented.
Buongiorno,
chiedo se possibile interfacciare i dati dei ciclocomputer Bryton in modo da scaricare direttamente i dati dall’applicazione senza dover passare da Strava o altro.
Grazie
I just logged a case with Bryton for either support for intervals.icu or Dropbox support (which intervals.icu can poll.
I really want to disactivate Strava as a source and Byton is ‘last man standing’
My current workaround for the lack of direct integration is as follows:
From the Bryton Active App (on iphone ) Click on the … in the top right hand corner
The select export FIT File
I then have an option to choose a location and as I have a dropbox account and app that option shows up in the screen below
The iPhone remembers the last used location therefore on interval.icu under Setting / Connections I have setup a Dropbox location to pull files from
Not 100% automatic but quite quick to do from the Bryton App.
I believe you can still create a free Dropbox account that has 2GB of space associated with it.
Hi, as many bryton users, I would like intervals.icu direct link to my activities as a new feature.
Maybe we have to ask for that feature at Bryton’s?
