Import Feeling from Suunto
Suunto watches can record subjective feeling after workouts. Is it possible to import this and use as Feel in intervals.icu?
If it is complicated to code, I understand it might not be worth the effort as it is easy to just update feel directly in the web app.
the question is: does that data get recorded into the fit file? in that case it should be easy to fix, given some fit files containing the data.
If that data only “lives” in the Suunto environment, than it’s probably not that easy
I think it is written to the fit-file. Runalyze imports it as “Subjective feeling “.
I can see it (5) in the fit file for this one: Intervals.icu
Do you know what the scale is?
1 to 5, or poor, average, good, very good and excellent on the watch
Herlas is correct about the scale. 5 is excellent.
I have added support for “feeling”. Note that the numeric scale for “feel” in Intervals.icu is reversed so “feeling” of 5 becomes “feel” of 1 and so on.
Wow, amazing support! It worked like a charm on today’s run. Thank you very much!
hi @david! Thanks for the great software!
Should the “feeling” data be syncing from Garmin as well? It doesn’t seem to be working for me…
Tx. Can you find it in the fit file on fitfileviewer.com? If so I can probably implement it easily (please point me at an Intervals.icu activity with the data).
It seems that the data doesn’t get included in the fit file :frowning: So propably nothing you can do…
